How to Split Oversized PST Without Breaking Folder Structure?
AlbertThomas
To split an oversized PST file without breaking the folder structure using DataVare Outlook PST Split Expert, follow a structured approach. The utility is meant to keep your mailbox safe while making the PST file smaller. Install and open the software first. Then, add the PST file that you want to split. Depending on what you need, you can choose to separate by size, date or folder. Choose the option that keeps the original folder hierarchy so that no emails or subfolders are lost. Set the destination folder for the output PSTs and then begin the splitting procedure. The software will make several smaller PST files while retaining the original folder structure. This will make it easy to access in Outlook without losing or messing up any data. This is the best way to keep Outlook from slowing down because of large PST files.
