How to Split PST in easiest way ?
The PST Split solution supports both ANSI and Unicode versions. It is an advanced sophisticated app that splits PST files without the size issue. Users can select any PST file without considering ANSI or Unicode.The Split PST is one of the most advanced tools and at the same time it is interactive. Its wizard is easy to understand.It splits any folder of a PST file and split data by year. It is a lightweight application that users can install on their systems without installing MS Outlook. After splitting a large-sized PST file into smaller pieces, they can be easily accessed with MS Outlook and are completely independent of original PST file. Just need to Download this tool
