How to Sync iPhone/iPad Data to iPhone 11/11 Pro/11 Pro Max
Tmzmo623
How to Transfer All Data from iPhone 7 Plus to iPhone 11 Pro?
How to Transfer Data from iPhone X to iPhone 11 Pro Max?
How to Transfer Calendar from iPhone 6S to iPhone 11?
How to Transfer Contacts and Photos from iPhone 8 to iPhone 11?
How to Transfer Text Messages from iPhone 6 to iPhone 11?
How to Transfer Videos from iPhone 7 to iPhone 11?
How to Transfer Apps and App Data from iPhone XR to iPhone 11 Pro?
How to Sync All Data from iPhone XS to iPhone 11 Pro Max?
How to Transfer All Data from iPad to iPhone 11?
How to Move Data from iPad Air to iPhone 11?
How to Sync Data from iPad mini to iPhone 11?
...And so on
Are you can not wait to buy a new iPhone 11/iPhone 11 Pro/iPhone 11 Pro Max to replace your old iPhone? Do you want to share/sync your data from the iPad to iPhone 11/iPhone 11 Pro/iPhone 11 Pro Max? If so, you must be interested in what is the best way to do so, right? Well, take it easy, what you need is just the Mobile Transfer.
Mobile Transfer also named as Phone Transfer, which is the all-in-one yet easy-to-use data transfer tool that can directly Transfer Music, Contacts, Photos, Videos, Messages, Calendars, Apps, App Data, Audio, Call Logs, Documents and other files from one iOS device to another. So, you can one click to transfer data from iPhone/iPad to iPhone 11/iPhone 11 Pro/iPhone 11 Pro Max by using this software.
Step 1. Download, install and run the software
Step 2. Choose a transfer mode
Step 3. Connect your iPhone/iPad devices to the computer
Step 4. Select the data for transfer from phone to phone
