How to Transfer Photos from Samsung to Huawei P30/Pro?
Tmzmo623
In the past, everyone may think that the design of Huawei mobile phone is not good enough, but Huawei's mobile phone and its design can be said to be very dry. The Huawei P30 series uses a water drop screen design. From the exposure design, the Huawei P30's upper and lower bezel technology can be seen. And the process has indeed been greatly improved, and the narrow upper and lower frame design makes the screen ratio undoubtedly greatly improved.
The screen size of the Huawei P30 is 6.3 inches, and the display of the mobile phone is Samsung AMOLED Magic Screen. The screen resolution of the machine is 2160×3840 pixels, and the aspect ratio of the mobile phone screen is 19.5:9.
As a Huawei fans, can't you wait to buy a new Huawei P30/Pro to replace your old Samsung Galaxy phone, if so, you must be interested in how to transfer photos from Samsung to Huawei P30/Pro, right? To get a faster and simpler data transfer experience, you can not miss the Phone Transfer.
Phone Transfer is the all-in-one yet easy-to-use data transfer tool that can directly Transfer Music, Contacts, Photos, Videos, Messages, Calendars, Apps and other files from one mobile phone to another.
Related: Transfer Photos from Android to Huawei P30/Pro
If you want to transfer photos from Samsung to Huawei, I think you need to use Phone Transfer software. It can connect your Samsung phone and Huawei smart phone at the same time and then transfer photos between them. You can also transfer messages, videos, contacts, music, apps and app data.
Well, there are so many modes to perform this transfer. You can do it manually by transferring the data from Samsung to a computer system via USB and then it to Huawei P30 Pro. Also, if you want to simply use a software, you are good to go.
