I’ve exported thousands of MSG files from Outlook and found many duplicates. What’s the best way to delete them safely?
If you’ve exported thousands of MSG files from Outlook and found duplicates, the safest way to delete them is using a specialized tool like TrustVare MSG Duplicate Remover. This software scans all MSG files, compares important attributes such as subject, sender, recipient, and date, and identifies duplicate emails and removes them with a few clicks. It removes only the duplicate MSG files while keeping your original emails intact, ensuring no original data is lost. The tool is easy to use, lightweight, and compatible with all Windows versions 11, 10, 8.1, 8, and 7. It doesn’t require MS Outlook to be installed, and a free trial is available to test its accuracy before purchase. Using this tool helps you organize your mailbox, free up storage, and improve system performance.
