daevenlate
InQuit OST to PST Converter software is designed with a highly advanced algorithm to perform the OST to PST Conversion task. With the help of this utility, your conversion task is easy. This application has a GUI which makes it easy for the user even a known technical user can easily handle it. This standalone application gives several benefits to an Outlook user for protecting their data from virus and another problem. After using this tool your email formatting will not be changed while you convert OST file to PST file.
Key Features of InQuit OST Recovery:
Support various file format:- This utility support multiple file formats like PST, EML, HTML, EMLX, vCard, vCal, MSG, MBOX which is the best part of this software. With the help of this tool, users can choose a different file format to save their data.
Cloud-based application: - Provide an option to store the records on the cloud-based application like Office 365 and Live Exchange Server which is an additional feature of this software.
Supporting Version:- This setup support MS Outlook version 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. Exchange server version like 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016. OS Windows’s version 95, NT, 98, ME, XP, Vista, 7, 8, 8.1, and 10 (32bit & 64bit).
Preserve Metadata property: - Using this tool you can preserve your metadata property like to, cc, from, date, time, object and bcc.
Download the free demo version of this application and see the immunity power and work performance of this tool. Demo version is free of cost that allows you to access 30 emails per folder. After purchasing it you are not satisfied with this so you can return it within 30 days.
