daevenlate
Use only InQuit OST to PST Converter that easily convert whole the data of OST file into Outlook PST file format without consuming more time. This application workable when MS Outlook is not installed in your system. You can use this software to export the OST mailbox data such as emails, inbox, send items, delete items, attachments, calendar, draft, task, notes( to, cc, bcc, from, object, time, and date). It is very simple to use for everyone. According to your need, you can break your large file into several small files and save them into Outlook PST and another file format such as PST, EML, EMLX, MBOX, HTML, MSG, vCal, vCard file format without losing data.
