InQuit Software Toolkit (EDB To PST + OST To PST + NSF To PST + PST Converter)
1 - Best Way to convert the data from EDB to PST
Hi friends, we hope you are happy and stat at your home. In these days we are suffering from a paramedic and due to this, we can’t go to our office. At this time lots of people work at their home. In this situation, if your Exchange file gets damaged then you have no technicians and no other way to solve this problem. But you know you can solve it on your own by finding the best and simple way. Today we will discuss the reasons for the EDB corruption and the solutions. Apart from it, we will also suggest the best tool that easily fixes your problem. To know all the solutions stay with us and read the blog from start to end.
How become EDB file get damaged
Hardware issue:
Due to the poor quality of hardware you may face this problem. Due to poor ventilation, bad sectors in the hard drive your Exchange EDB file get damaged.
Power outage: When you working on the Exchange server and suddenly the power is cut, then you face power outage that makes the EDB file unapproachable.
Software crash: When you install third-party software on your system and it not working properly. It might also be the cause that there is a problem with your system.
Exchange Server crash: Due to hardware, software, and any other reason the Exchange server can crash and your system gets shutdown.
How to get lost data again?
There are lots of ways to access the lost data again. If you want to recover the data from the manual method then it takes lots of time. Apart from that, there is a simple way that is third-party solutions. For your help, we suggest the best and award-winning software that is InQuit EDB to PST Converter application. This application has the capability to recover the data from the damaged file then convert them into new Outlook PST file formats.
It’s simple to process to make the recovery process smooth and reliable. To access the lost data again, it is the perfect choice for those users who are suffering from the same problem.
Why select only InQuit EDB to PST Converter?
It is a point why only select InQuit EDB to PST Converter. As we know there are lots of third-party tools that provide the same services. So what is unique in this product? There are lots of questions on your mind but don’t worry we will describe why use only this EDB Recovery tool. As we know believe is most important among vendors and buyers. This application has many features than other software. This application has many features for your help that make the conversion process very smooth and reliable. We also create a strong bond with our customers that is the main reason to purchase this product. Apart from it has lots of features that are mentioned below:
  • Using it you will be able to convert encrypted and password protected files also.
  • There is no need to install MS Outlook on your system because it is also capable to work in the absence of MS Outlook installation.
  • The application supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
  • You will be able to convert single mailboxes as well as multiple mailboxes which includes an inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time).
  • Migrate EDB files directly into the Live Exchange server and Office 365.
  • For your satisfaction there is a free demonstration to convert 30 emails free of cost.
  • It supports MS Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
  • Compatible to extract the data into PST, EML, EMLX, MSG, vCal, vCard, and MBOX file format without any extra efforts.
  • It provides 30 days money guarantee which makes this tool completely risk free.
Read more info :
2- Adorable Features of OST to PST Converter Software to Repair & Convert OST File to PST Outlook
Auto scanning facility:
The auto scanning facility of this tool gives the best service in which you can scan the OST file then easily migrate the data into Outlook PST file format.
Don’t change the originality: The user’s also tense about their data’s originality. But in this utility, you don’t need to worry. It doesn’t change the originality of the database while you transfer the data of OST into Outlook PST.
Export more than one file: The users can easily convert the data of OST file into Outlook PST file. Even it also converts a bunch of 100 files at the same time.
Support many file formats: Allows us to Save OST file to PST, MSG, EML, EMLX, MBOX, vCard, HTML, and vCal.
Split file
: Split oversize PST file during conversion; define size from 1 GB to 25 GB to makes PST file small.
Batch Conversion: Batch Conversion OST (multiple OST file and Folder) Process in PST File at the same time.
Support Office365 and Live Exchange Server: You can also convert their data into Office365 & Live Exchange Server that is a surplus feature of this setup.
Support MS Outlook version: This utility is compatible with all the versions of the MS Outlook 2003, 2007, 2010, 2013, 2016, 2019 and all the above versions. The users can easily install it on windows version up to Win 10 (62 & 64 bit)
These all the facilities are readily available in one utility. You can easily download it from its official site at a reasonable price. Before purchasing it, you can also evaluate the working performance of this setup. To do it, download the free demo version of this tool to convert 30 emails per folder free of cost that is the best opportunity for you.
Read More info:
3- Using Third party tool InQuit NSF to PST Converter:
InQuit Lotus Notes NSF file to Export Outlook PST
export to PST
export to EML
export to MSG
export to vCard
export to HTML
export to EMLX
export to MBOX
export to CSV
export to Exchange server and
Export Lotus Notes email data to Office 365
InQuit NSF to PST Conversion tool is most powerful and advance technology. This tool is easily retrieve Lotus Notes Mailbox data such as Inbox, Contact, Calendars, Task, journals, bookmarks, address book etc and convert to outlook PST file formats. NSF to PST Software is easily export lotus notes mailbox all data to cloud application office 365.
Some most Important Key features
  • Easy way to retrieve all Lotus Notes mailbox version as 10.1, 9.1, 8.5, 8.0, 7.5 and blow version.
  • Recover all perspired hidden mailbox data as emails, contacts, task, journals, notes, documents etc.
  • Convert recover NSF to Outlook PST, MSG, EML, EMLX, MBOX, vCal, vCard, HTML formats.
  • Easy way to direct export Lotus Notes file to office365 & Live Exchange Server.
  • Simple GUI to handle to Technical and non-technical users.
  • No Required to Install Outlook in Conversion process NSF to PST.
  • Software support all windows version.
    Simply Works the MS Outlook Versions (97 up to 2019) and This Tool is Windows Supported application.
    Read more info: NSF to PST Converter
4- Best Outlook PST Recovery
InQuit Outlook PST Recovery is a simple, easy to use which is designed to repair outlook emails to PST file by recovering damaged files from all type of corruption. It provides formats such as PST, EML, EMLX, vCard, vCal, MSG, MBOX and HTML which include inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). This utility is designed in a way that it retains the integrity of data after the conversion of Outlook PST file. This application supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016, 2019. A free demo version to convert 30 emails in each and every PST folder free of cost given by this application.
Read more info: Outlook PST Recovery
Summary
In the end, we would like to say that there is no force to select only this software, if you are happy with our clarification then you can always install this software on your system. It helps to repair, recover, and convert the data from EDB to PST + OST to PST + NSF to PST + Outlook PST Converter.
Read More: InQuit®Software
BUY NOW
BEST PRICE :-
InQuit®Software Toolkit Offer (EDB To PST + OST To PST + NSF To PST + PST Converter)
I used good & different solution name of KDETools OST to PST Converter software minimum a few days ago.
• It allows multiple types of conversion like OST to PST Outlook format included 14 plus formats like- PST, Zimbra, Gmail, vCard, ICS, office MSG, EML, EMLX, MBOX, PDF, NSF, and etc.
• OST to PST Converter also offers a preview of OST data before conversion.
• Users can save all OST files into a single file or Convert a single OST into a single PST file.
• There are no size restrictions for OST to PST conversion.
• User can split PST file into smaller files.
• Message filtration
• No requirement of MS Outlook.
MOre info- Convert OST to PST Outlook
