Is there a reliable method to split a huge vCard (.vcf) file into separate contacts?
garycarter
Managing or sharing a big vCard file with hundreds or thousands of contacts can be challenging. To keep each contact safe and manageable it is best to divide that large file into smaller VCFs. It is difficult to do this manually because-Data loss frequently occurs when editors open huge VCF files.
Manually cutting the file risks breaking the contact structure.
Some devices or email clients cannot support sharing or importing large vCards.
This can be resolved by using a trustworthy utility that splits a large vCard into multiple smaller files without erasing any information including name, address, phone number or email. The procedure is made easy, fast and precise with the help of a professional tool like Softaken Split vCard Software. It ensures that every contact is saved in a separate VCF file while maintaining the integrity of the original data.
