jackharris
Yes, you can import contacts from Outlook onto Xiaomi or Oppo phones by exporting them to VCF in a simple manner. The ideal way to handle your Outlook PST contacts is to convert them to vCard (VCF) format, which these cell phones support. Without erasing any data, you can rapidly extract all of your contacts from Outlook PST files and save them in VCF format with a trustworthy solution like TrustVare PST to VCF Converter. Details like names, phone numbers, email addresses, and more are kept completely accurate by it. Batch conversion is another feature of the software that lets you export several contacts at once. The VCF file is simple to import and transfer to your Xiaomi or Oppo phone after conversion.
