Keyboard logger detected
Bogey62
After installing Eraser v5.82 my spyware program reports a keyboard logger present in the archive. Should I be concerned about this?
The official archive is free of any spyware. I suggest yuou download the latest version which is digitally signed see announcement on forum.
Garrett
Garrett
I downloaded it from this site.
If you downloaded the latest 5.84 can you tell me what dll/exe is reported as having spyware and is it the 64bit or 32bit version?
What scanner are you using? and is it the latest version?
Garrett
Garrett
It was one version back (32-bit) and I am using PestPatrol to scan with. It doesn't report a keyboard logger on my computer, but does report it as part of the archive. I have since downloaded the 5.84 32-bit version and the scan reports nothing unusual.
Ah Pest Patrol (Known for false positives), I'd double or triple that result with SuperAnti-Spyware or some other Anti-Spyware scanner or a online scan or copy the file from Pest Patrol's Quarentine folder and send it to http://www.virustotal.com/
I also use Zone Alarm Security Suite and it showed nothing negative on either Eraser archive.
Thanks for the quick responses and a fine product.
