davidwilliams
If your large ZIP file is not converting properly, I faced the same issue earlier and found that it usually happens due to file corruption incomplete download or size limitations in some basic tools. In my case, switching to Softaken Archive Converter Software solved the problem completely. The application is made to work well with big ZIP files without losing any data. It can convert many files at once and keep the folder structure, attachments and file integrity intact. Check to see that the ZIP file is not password protected or damaged before converting it. Install the application, add the big ZIP file, pick the format you want to save the file in, and then start the conversion. It works well even with big archives and does not freeze up while it is working. I changed ZIP files that were many GB in size without any problems. If manual methods or free tools fail to function, I highly recommend giving this software a try for a quick solution.
