Lotus Notes to Outlook PST Conversion
Lotus Notes to Outlook PST Conversion is now the easiest task if you go with eSoftTools NSF to PST Conversion software. The software offers to load unlimited size of Lotus Notes NSF file and open it within a minute. This solution is 100% safe, secure and reliable and it does not harm any single byte of information in NSF file. Once software loads NSF file, you can jump over the conversion wizard where you can save/ convert NSF into PST, EML, EMLX, MBOX, MSG, HTML, CSV, VCF, and ICS file.
Get the demoware software from-
Using this NSF to PST Converter tool is the easiest way to convert Lotus Notes NSF file data to Outlook PST file format. It can also save NSF file into other formats like MSG, EML, RTF, PDF & HTML. It quickly converts NSF mailbox items to Outlook PST format in a few simple clicks, while preserving the original data format. This tool allows the user to directly export mailbox data to Office 365. The tool supports Windows 10, 8.1, 8, 7, Vista, XP OS. To know more about the tool, visit: https://www.datarepairtools.com/nsf-to-pst-converter.html
With the support of NSF to PST Converter Software, which has a lot of features, you can export all of your data in a large quantity. It stands out from other applications because of its incredible features. You can convert any size NSF file to Outlook PST format with this method.
It can be used in the absence of MS Outlook, but it requires Outlook to open data in a new format. Before the conversion, you can see the preview and re-collect emails, inbox, sent the item, draft, delete-items, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object, and Time) into a new healthy PST file
Someone's issue is about. “Convert Lotus Notes Email to Outlook''. I would advise them to use Softaken Lotus Notes to Outlook Converter Software. It works in a few clear and easy steps. During the Lotus Notes to Outlook conversion, email properties are maintained. To convert required emails from a Lotus Notes file, the user simply needs to select the mail filtering option and choose the from and to dates. The trial version also available for all customers in the demo version you may covert few email items per folder without any charges.
