MBOX to PST Converter
I recommend eSoftTools' outstanding MBOX to PST Converter tool, which can convert all MBOX email to PST and work with all versions of Outlook 2019, 2016, 2013, and earlier. The application has a variety of advanced features and benefits that aid in the conversion process. The following qualities are explained in further detail:
1. You can convert a huge number of MBOX emails to PST at once using the batch feature.
2. You can use the preview function to receive a quick overview of an email before converting it.
3.Supports all Microsoft Outlook versions, including the latest.
4.Selective conversion of MBOX emails to PST using advanced filters
5.All Windows operating systems are supported, including Windows 7, 8, 10, and others.
Get more info- MBOX to PST Converter
Download this advanced tool acquired called Free MBOX to Outlook Converter it gives a free demo version of their software. In the demo version, the user can obtain MBOX mailbox items from each folder of the MBOX file, and for high-level features, the user can purchase a premium version of the software. In the premium version, user can export MBOX file into PST simultaneously with all emails, attachments.
The BLR MBOX Converter Tool easily converts your MBOX emails into PST format and works with all versions of Outlook. This tool comes with a range of advanced helpful features to make the conversion process simple and efficient:
  1. Convert multiple MBOX emails to PST at once using the batch conversion feature.
  2. Preview your emails before converting them to make sure everything looks good.
  3. Works with all versions of Microsoft Outlook, including the latest ones.
  4. Allows selective conversion of MBOX emails with advanced filters.
  5. Compatible with all Windows operating systems.
One can get the trial version of the MBOX converter tool for free.
