Moving contacts from an old phone left me with a VCF file — how do I convert it into CSV format?
bradleymorales
When you move contacts from an old phone, you normally get a VCF file that includes all of your saved contacts in it. When you want to use those contacts in Excel or another tool that needs a CSV file, that is when things get tough. You are unable to just open a VCF file in Excel because it is not the same as a CSV file. It will look disorganized or hard to read. A lot of individuals want to know how to convert VCF file into CSV file, especially if they have a lot of contacts on their phones. You could miss information or have formatting errors if you extract the data manually or use an online converter that does not work, which can be very annoying.
The best approach to do this is to use the DataVare VCF to CSV converter, which was created particularly for this purpose. These apps can move contacts from VCF to CSV without losing important information like names, phone numbers, emails, and addresses. They also enable you convert a lot of VCF files to CSV at once, which is helpful if you have backups from more than one device.
When you use a dedicated converter, you can be sure that your VCF contacts will be appropriately converted to spreadsheet format, making it easy to import them into Excel, Google Contacts, or other contact management systems. This plan makes it easy to move your contacts from your old phone and sort and manage them. If you have a VCF file and want to convert it to CSV format, look for software that can accomplish the job fast and keep all of your contact information intact.
