MSI installer for AD
chabral
Hi,
Does an .msi installer exists for Eraser 5.7? I'd like to deploy the installation on a small group of PC administered using active directory. If someone can provide me with this it will be really helpful :)
Thanks in advance,
chabral
It did and we were nearly wiped off the map with support calls.
The current version in Beta (see announcement) has a silent install option.
/NORESTART
Instructs Setup not to reboot even if it's necessary.
/NOCANCEL
Prevents the user from cancelling during the installation process, by disabling the Cancel button and ignoring clicks on the close button. Useful along with '/SILENT' or '/VERYSILENT'.
/SP-
Disables the This will install... Do you wish to continue? prompt at the beginning of Setup.
/SILENT, /VERYSILENT
Instructs Setup to be silent or very silent. When Setup is silent the wizard and the background window are not displayed but the installation progress window is. When a setup is very silent this installation progress window is not displayed. Everything else is normal so for example error messages during installation are displayed and the startup prompt is (if you haven't disabled it with DisableStartupPrompt or the '/SP-' command line option explained above)
If a restart is necessary and the '/NORESTART' command isn't used (see below) and Setup is silent, it will display a Reboot now? message box. If it's very silent it will reboot without asking.
Garrett
