need help please
  • Start date Start date
I can get all my desired files onto the "on demand scheduler" , and can erase them. The PROBLEM is... after they are wiped and i proceed to exit , all of the files disappear from the scheduler. Do I have to re- enter the files every time I want to erase?? Is there a way to allow the files to stay on the scheduler , so I can erase with only a few clicks ( Task and Run All)??? Thanks
:) In the 'Task Properties' box, tick the 'Keep task on the list' box to retain the file/folder on the scheduler.
Cheers :P lovelyperson
THANK YOU IT WORKS !!!! Do you know how I can erase e-mail ??
How do I erase it after I delete it in Outlook Express ??? Thanks
