Need Help regarding failures..I am New here!!
pk16
I just erased the unused disk space on my C drive. What does it mean if I had a bunch of things come up in the Failures Box at the bottom after Eraser was completed?? Does it mean It didnt erase any previous data i had on my computer?? Im trying to eliminate old files i deleted a while ago. Thanks for the help!
Hi pk16.
I doubt you have anything to worry about. The failures are usually files that windows has locked, system files etc.
Perhaps you could post the failed files list and I could tell you more.
