As we know, IBM Lotus Notes saved their data in NSF file and it's not accessed in a straight line with MS Outlook when it saves NSF file into PST format then you can easy to convert NSF file to PST format in MS Outlook. The need for Lotus Notes to Outlook conversion software? eSoftTools Lotus Notes NSF to PST Converter tool helps to import and convert Lotus Notes to Outlook by migrating NSF file to PST file. This tool can smoothly export lotus notes emails and other items like -emails, their components, contacts, calendar, and attachments.
Some Steps
Download and Install the software
Run the software
Browse your while
Now select and open NSF file which you wan to convert into Outlook.
Read More -
eSoftTools NSF to PST Converter - Pricing, Reviews, Alternatives and Competitor in 2019
			Some Steps
Run the software
Browse your while
Read More -
