NSF file conversion
I want to recommend you eSoftTools NSF to PST Converter software because this tool gives you all the required features that are important for NSF file conversion. Its converts Lotus Notes NSF file to PST and many other file formats such as EML, EMLX, HTML, ICS, CSV, VCF, MSG, Zimbra, Office 365, Yahoo, Gmail, and MBOX. With this tool, you can easily convert any size NSF file by date range. Check the free demo version of this tool and get 25 mailbox items from each folder.
Read more- NSF file conversion
Softaken Lotus Notes NSF to PST Converter is the most powerful and user-friendly third-party email conversion software available, allowing customer to Migrate multiple Lotus Notes address book to Outlook in only a few clicks, as well as export NSF data to EML, MSG, and HTML formats. It works with all versions of Lotus Notes, Outlook, and Windows. It has a lot of features.
Important features of the tool
  • It migrates multiple NSF to PST at the same time & without any problems.
  • Save data into EML, EMLX, MBOX, MSG, HTML, and MHTML formats
  • Provide Mapping option
  • Supports all versions of Lotus Notes, Outlook, and Windows OS
Users can download a free trial version of the utility that allows them to test all of the tool's features and capabilities, as well as convert the first 10 items in each folder.
I would like to inform users that there is no direct path to open NSF files in Gmail. So, for that users try NSF to Gmail Converter which is an excellent solution that will easily, the software comes with advanced features to perform conversion and even offer a free demo version as well.
More Info:- Transfer Lotus Notes to Gmail
NSF file formats comprise the most common database files that store mailer data, like emails, calendars, and journal entries for contacts, as well as tasks and more. You can, however, access the NSF format with only Lotus Notes. However, Gmail is the most popular email client. It can be used for personal and professional use. If you want to access the NSF file in an account in your Gmail account, you'll have to be aware of the correct procedure. Read this informative article to help you open NSF File in Gmail account without modifying your data.
In addition, you can utilize an alternative Cigati NSF Converter to open or convert an NSF file into Gmail. It is the most secure and trusted tool that comes with an easy-to-use user interface.
