NSF to PST Conversion Software
eSoftTools NSF to PST Converter Software is a trustable tool that has the ability to convert any encrypted and large size NSF file to PST in just one go. Without harming the internal data, it converts NSF files into 8+ file configurations and split the enormous size NSF file during the conversion process. This utility exports selected NSF files with mailbox components and email attachments like to, bcc, cc, from and date. I offer you to migrate 25 items from every envelop.
Get more info:
For the same, Shoviv NSF to PST Converter is the most advanced tool that comes with the numerous features for the ease of the process. Shoviv Software allows converting multiple NSF files to PST with no size-limit. It offers features like Item filter, Email Translation, Folder mapping option etcetera as well as it helps to export the multiple NSF data to EML and MSG formats. The free demo/trial version of Shoviv NSF to PST converter is also available that allows converting the first 50 items per folder.
More details, visit:- Transfer emails from Lotus Notes to Outlook
Lotus Notes NSF file to Outlook PST Conversion would be simple if you are using professionals NSF to PST Conversion Guide. It successfully exports emails, messages, calendars, contacts, to-do lists, tasks, notes, etc to a new PST file at user-defined location. If you have multiple NSF database files, you can select all of them and perform their batch conversion in just a single conversion cycle.
NSF to PST Converter tool is the most effective application to convert and upload all IBM Notes NSF data like- Emails, Contacts, Tasks, To-do Lists, and Calendars to Outlook PST. It Keeps the original folder structure and Metadata properties while converting Notes Lotus NSF data to Outlook PST. It has a simple UI, so anyone can easily operate the software without any technical supports. It also gives a free demo version for the users.
eSoftTools NSF to PST Converter Software performs fast and secure conversion process to convert Lotus Notes to Outlook format with all NSF folders emails, calendars, contacts, drafts, tasks, and journals etc. The software has the capability to migrate nsf files to pst along with mailbox items- calendars, emails, journals, emails, and all the attachments – to, bcc and cc. The tool has multiple features through which you can safely migrate NSF files to PST instantly without much difficulty. Users can preview their NSF files before conversion and select NSF files for conversion. The NSF to PST converter software helps to speedily export the NSF files to Outlook in bulk and Split large size NSF files while conversion.
Read more:
