NSF to PST Conversion Tool to export NSF files to PST
To recover any kind of NSF file, you can easily convert it to Outlook PST with this excellent tool which is eSoftTools NSF to PST Conversion Software that immediately works with advanced technology. It is capable to convert NSF files along with their email elements like drafts, journals, notes, calendars, meeting, and contacts and software also able to repair corrupted NSF files within seconds. In this software you also get the feature of trail version that helps you to secure email properties like to, bcc, cc, from, and date and also maintains the folder structure exactly.
Visit here:
Take the help of the finest Lotus Notes to Outlook Converter Software. This tool is useful to transfer unlimited Lotus Notes NSF files to Outlook PST format without losing information. The tool allows users to convert NSF files in batch to save time and effort. It successfully supports NSF files created by any NSF supportive tool. This software is compatible with all the versions of Windows OS & MS Outlook.
Shoviv Provides the best and error-free conversion tool name, Shoviv NSF to PST Converter tool. This tool equipped with multiple features. It helps to converts the multiple Lotus Notes NSF mailboxes to Outlook PST at the same time without any intrusion. It also capable of export data into EML, and MSG formats. Shoviv NSF to PST Converter tool allows the users to preview the NSF data before the conversion of NSF data items into PST file format. It supports all versions of Lotus Notes, Outlook, Domino Server, and Windows OS. Download It free trial version and convert the first 50 data items per folder.
There are several NSF to PST converter available in the google, but eSoftTools NSF to PST conversion tool is the best because it gives 100% accurate result to the user. This software supports all Outlook versions like Outlook 2019, 2016, 2013, 2010, 2007, 2003, 2002, and 2000. The tool not only recovers the mailbox of NSF but also contacts, journals, calendars, events, tasks, and much more within a least time. User can also split the oversize PST File by size upto 5GB and convert selective single and multiple NSF folders with attachments. A FREE DEMO pack is available, up to 50 emails can easily be converted into all formats.
You can buy this application from its official website.
Visit here form more info:
