NSF to PST Conversion
The highly recommended tool by experts and administrators for NSF to PST Conversion is eSoftTools NSF to PST Converter Software that converts the selected NSF files in to PST, EML, vCard, MBOX, MSG, vCal, EMLX, CSV, ICS, VCF, HTML and others. This tool never loses any email header structures and keep maintain To, CC, Bcc, Subject, Date & Time, Attachments. Perform NSF to PST Conversion with 100% accuracy and also supports all IBM lotus notes up to 10, 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0 versions. You can select NSF mailbox items for conversion and can preview them with complete data. It keeps the folder and sub folder hierarchy intact and also is capable to export any size of Lotus Notes NSF file in to Outlook. It is compatible with all editions MS Outlook up to 2019.
Download the demo edition of software from-
Bitdataconversion NSF to PST Converter is a professional tool which makes migration task very easily. It’s a truly incredible solution for all users to convert or migrate multiple NSF files to PST, EML, and MSG without any interruption. It supports all versions of IBM Notes, Outlook, and Windows OS. Download its free trial version and migrate the first 50 items per folder.
For more details, visit - NSF to PST
Softaken Lotus Notes to Outlook Converter Software is a third-party tool that allows users to convert Lotus Notes to Outlook files quickly and easily. NSF to PST Converter converts NSF to PST, EML, MSG, HTML, EMLX, and a variety of other file formats. This is a fully secure and safe application that converts Lotus Notes NSF files to PST files freely and fully. Users can also take advantage of the free trial demo version, which allows them to convert 10 emails per folder from an NSF file to any format at no cost. I've already used this software and can tell you that it will cure all of your problems in a matter of minutes.
