Converts the multiple NSF data files to PST with the help of the best powerful tool - Bitdataconversion NSF to PST Converter tool
Bitdataconversion NSF to PST Converter provides the best solution for NSF to PST Conversion. It converts unlimited NSF data at the same time into Outlook PST and exports data into EML and MSG formats. The tool gives the easy to use Graphical User Interface, any user use this tool very easily. Users run this tool in any versions of IBM Notes, Outlook, Domino Server,
Important Highlights of the Tool
More details, visit:- Lotus Notes to Outlook
- Converts multiple NSF data at the same time without any data loss
- Provide Error-free conversion
- Save data into EML and MSG format
- Easy to Use the graphical user interface
- Mapping, Split, and Filter options
- Run In any version of IBM Notes, Outlook, and Windows
- Free technical support
- Free demo available which converts 25 data items per folder
