NSF to PST Converter tool
Freeware Recover unlimited NSF file data into Outlook PST file any size limit with the help of Vartika NSF to PST Converter Software, this utility quickly repairs all corrupted NSF file just in a few seconds. In this tool, Users can comfortably export NSF files into different file platforms like Office 365, Live Exchange Server, MBOX, EML, EMLx, MSG, MBOX, HTML, vCal, vCard, CSV, PST file folders. A smart live preview option is available in this software just watch the recovery or conversion process of NSF file, and also you can easily check and confirm you’re your corrupted NSF file data recovered or not. A FREE DEMO pack is provided by Vartika NSF Converter Tool, in which users can transfer up to 30 email items from every folder that can be converted into all formats without any cost. This utility is eligible to supports all the versions of Lotus Notes 10.1, 9.0, 9.0.1, 8.5, 6.0, 8.0.2, 7.0, and 6.5 versions.
Find more details:Zimbra to PST Converter Software | Convert Zimbra TGZ to PST
Bitdataconversion NSF to PST Converter Tool is the best application and easiest way for NSF to PST Conversion. Using it, users can convert single as well as multiple NSF data files into Outlook PST at the same attempt without any intrusion. This application has a preview facility that shows the preview of all mailbox's data before finishing the conversion task of the NSF data file to PST. It also able to exports data into EML and MSG formats without any intrusion and supports all versions of Lotus Notes, Domino Server, Outlook, and Windows OS. Download the demo of this tool and also convert the first 50 data items per folder.
For more details, visit - NSF to PST
Download eSoftTools NSF to PST converter that is one and only solution to restore the mailbox items of NSF file and also shows the preview of selected NSF files. This software does not harm the folder hierarchy of the NSF and provides you the multiple file patterns for conversion like EML, PST, EMLX, CSV, VCF, RTF, vCal, HTML, MBOX, and so forth. It has the ability to preserve the email properties even after the conversion and do not need Outlook application installation. FREE DEMO EDITION to save 30 items per folder.
Read more -
Try this amazing Softaken Lotus Notes to Outlook Converter Software that allows you to convert multiple NSF files to PST, EML, EMLx, MSG, MBOX, HTML, MHTML, etc. Users can convert NSF files to PST with its mailbox elements like emails, tasks, drafts, calendars, journals, and contacts. You can preview the selected Lotus Notes mailbox and can convert a few items per folder by using its free demo version. The user can perform conversion with just a few simple steps because the software is smooth and reliable.
