NSF to PST
If you want to migrate NSF file into Outlook PST so it is possible with help of NSF to PST Converter migration tool. By using this software you can easily create batches for saving the NSF database. This application provides a very helpful opportunity to extract NSF data into Office365 & live Exchange Server. It has other features that are here:
• This application can do fast recovery of Outlook file into PST formats.
• Compatible with all the versions of MS Outlook up to 2019.
• 24x 7 technical supports
• Conversion of inbox; outbox sent-items, deleted-items, drafts, contacts, calendar, and note (to, cc, bcc, subject, date and time).
• Supportable PST, MSG, EMLX, MBOX, CSV, vCal, vCard and EML formats to save NSF data
• Automatically scan all the flaw of NSF file
• The preview of the recovered mailbox before the conversion
• Free demo version to convert 25 emails in every folder
• 30 days money back guarantee
Read more: https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
NSF File to Outlook Converter tool successfully export your all NSF mailbox data to Outlook PST file format. It's capable of migrating your all NSF mailbox data like emails, contacts, email messages, tasks, appointments, attachments, notes, images etc. from the PST file. Its software is also well works on all versions of MS Outlook and Windows platform.
More Info :- NSF File to Outlook Converter
Shoviv Lotus Notes to Outlook converter is the ultimate solution for the user. The software has the capability to convert multiple Lotus Notes NSF files into Outlook PST as well as EML, MSG, and HTML. It gives safe and secure conversion. It is perfectly compatible with all versions of Lotus Notes, Outlook, and Windows OS. Download Its free trial version and migrate the first 25 items per folder.
More details, visit:- Lotus Notes to Outlook (NSF to PST)
1247
For easy and instant migrate your Lotus Notes to Outlook data with the help of Tool to Convert NSF to PST Software. It transfer all NSF mailbox data like contacts, email messages, tasks, appointments, attachments, notes, images, etc. from the PST file format. NSF to PST converter provides 24x7 technical support for using NSF to PST converter application.
