Office 365 Backup Solution
alex786
Microsoft is a renowned organization that offers Office 365 but has some limitations in backing up its data. Office 365 does not allow recovery of the deleted after 30 days. So it initiates the requirement for a third-party Office 365 backup solution that creates a backup of Office 365 locally. One such software is Shoviv Office 365 backup & restore, which is an excellent utility to make the backup of Office 365 into a PST file.
Users are free to add several Office 365 mailboxes and take backup concurrently. Its scheduling option comes in handy if you need to backup periodically. There will be a situation you might face if the process is interrupted. This tool ensures every interrupted process resumes while eliminating the data files duplicity. It gives much more advanced-level functionality, which makes the backup process more convenient. To check them all, try its free evaluation version.
Get More Info: Backup Office 365 emails
If you need to backup Office 365 mailbox data to Gmail quickly, you can use our most efficient Office 365 Email Backup Software. This application is used to export data from multiple Office 365 mailboxes, such as emails, contacts, calendars, tasks, and so on, to CSV, MSG, HTML, PDF, EML, etc. It can import Office 365 mailbox folders to Gmail, Yahoo Mail, iCloud, HostGator Email, Amazon WorkMail, Opera Mail, Live Exchange, Zoho Mail, Hotmail, and Yandex Mail, among others.
DRS Office 365 Email Backup Tool is a best choice among all the IT professionals to backup and restore entire Office 365 emails to various file formats and emails clients. The software has a capability to backup entire mailbox data from the mailbox, archive folder, and public folder. The software has a wide compatibility with all the MS Windows and Mac versions. You can download and run the demo version of the software to check its internal functionality and backup 50 emails per folder for free.
There are few more prominent products designed by DRS Softech are:
AOL Mail Backup Tool
PST Converter
MySQL Database Repair Tool
Maildir Converter
OneDrive Migration Tool
Yahoo Backup Tool
CSV to vCard Converter
Thunderbird Backup Tool
EDB to PST Converter
GoDaddy Email Backup Tool
PST Password Remover
Outlook Duplicate Remover
EML Converter
EMLX Converter
MBOX File Converter
MSG File Converter
PST Compress
BKF Recovery
Email Migration Software
SQL Database Recovery Tool
SQL Backup Recovery
NickMorris1
If you want to take a backup of your Office 365 Account. you can use Cloud Backup Tool, this tool easily works on Windows OS. And it allows you to backup Office 365 emails, into PST, EML, EMLX, MSG, MBOX, HTML, and MHTML. It just takes a few minutes to install, and it does so without losing any of the data on your computer. If you want to know about its functionality then you can download its free demo version and backup your 25 emails.
sachin12singh
MailsDaddy Office 365 Backup Tool is an excellent solution for backup Office 365 database. It provides the facility to backup multiple Office 365 accounts with login credentials. Using this tool, you can backup all data such as email, contacts, calendar, and tasks of Office 365. It can save your important Office 365 emails in PST, MSG, MBOX, and EML formats.
Office 365 export tool is a professional solution that allows you to take backup of Office 365 data into various file formats such as PST, PDF, EML, MSG, MSG, and MBOX. Moreover, the utility supports all versions of Windows OS like 10, 8.1, 8, 7, Vista, XP, etc.
If you are searching for an effective solution to backup your Office 365 mailbox data then you should opt for a secure and reliable Office 365 Migration Tool. This software approach will assure high data integrity and offers some advanced features that allow users to optimize the whole migration process.
However, suppose you want to migrate your data from one tenant to another. In that case, you can go through this informative article that precisely explains the detailed process of Office 365 Tenant To Tenant Migration. Also, you can accomplish this migration by using this effective Office 365 migration tool. It is capable of executing this task by ensuring high data integrity.
Office 365 Backup Tool can download Office 365 mailbox to PST, EML, HTML, EMLX, and others. Its smart mail filter option also allows you to select your mail within a specified date range. And it also backup or migration of email into several email clients like Gmail, Hostgator, AOL, and others. This Office 365 Email Backup Solution also restores OST/PST to Office 365 and offers an easy solution to save Office 365 data on the local system.
