danielwillimson
Outlook for windows doesn’t support OLM files. Consequently, if you want to access your OLM files in MS Outlook for windows, you must to export all your OLM files data to PST then Import the entire PST files data to Outlook for windows. Thus, of a user is moving from Outlook for Mac to Outlook for windows, then they have to convert OLM to PST. Here providing the direct method to convert OLM files to PST files; quickly download the best Vartika OLM to PST Converter Software that provides complete conversion of OLM files to PST Outlook file. Also, you can export OLM files to PST files, apple mail and office 365. This is the easiest way to convert OLM to PST with all data included- emails, contacts, calendars, task, notes etc. Software has no compatibility issue and supports all versions of MS Outlook such as- 2019, 2016, 2013, 2010 & below versions and windows OS such as- windows 10, windows 8.1, windows 8 etc. OLM to PST Converter Software allows users not only convert data of OLM file to PST file but also convert different types of formats such as- EML, MSG, MBOX, EMLX and HTML format with emails, contacts, calendars task etc.
Read more :Vartika OLM to PST Converter- PST, EML, MSG, MBOX and Office365
