OST Recovery Tool
Safely download eSoftTools OST Recovery Tool that is a 100% trustful software that converts OST file into multiple file designs like PST, MSG, MBOX, HTML, office365, VCF, EML, EMLX . The conversion of OST file that has simple and comprehensive user interface. This tool is basically designed to repair OST file with it's email properties tasks, journals, calendars, drafts, and contacts. It essentially exports selected OST files without the installation of MS Outlook application and also preserves the folder hierarchy along with emails headers like to, bcc, cc, from, date, and subject. The software enables to work with older and latest version of the MS Outlook and Windows editions up to 10. Here you can convert number of OST files in just one click and select the saving path in PST.
Come and download the free software and export 25 OST emails from every folder.
Visit here to download: OST Recovery
If you are not getting a solution for OST file recovery. Here, I am providing you a safe and reliable solution for the conversion of OST files to PST and multiple file formats. It also recovers OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals, and draft, etc. It also supports all Mac OS versions. This software supports all MS Outlook versions like:- 2019, 2016, 2013, 2010, and 2007. You can download the free demo version for OST to PST Converter for Mac Software.
Best OST Recovery has following features:
• While users export their data from OST file to PST file it does not change the integrity of the Database.
• After the conversion task provides an accurate result as per your requirement.
• Support OS Windows’s version Win 95, Win NT, Win 98, Win ME, Win XP, Win Vista, Win 7, Win 8, Win 8.1, and Win 10 (32bit & 64bit).
• It provides 24x7 technical support for the users.
• The users also able to convert OST data into PST in the absence of MS Outlook installation.
• The size of OST or PST file does not matter because it easily handles all sized file easily and safely.
You can convert your data into formats like PST, EMLX, MSG, vCal, vCard, EML, and MBOX.
• Through the aid of this program, users can convert single as well as more than one OST.
Read More: SysOZ OST Recovery
