Get the best deal on the eSoftTools OST Recovery tool which tool can support all editions of OST file, Windows 10, and MS Outlook up to 2016. Instantly convert your OST files with all email attribute such as- cc, bcc, time, date, subject, sent items, deleted items, etc. The OST Recovery tool is 100% safe, simple, and secure with easy interface even technical or non- technical users. The tool has given a free demo pack to export 25 emails or items from each and every per mailbox.
Get More Know- OST Recovery tool
camilia
Try best ost to pst converter free software to transfer data from offline ost to pst converter 2019 with save all emails properties such as- To, Bcc, Cc, subject, date, from and etc. The conversion solution tool has smart technology to recovers emails, images, dates, contacts, task, calendar, etc. This application of best ost to pst converter freeware tool 100% Supporting all versions of MS Outlook 97, 98, 2000, 2002, and 2003 & 2019.
Batch Conversion Option.
Split option.
Messages Filters option.
No file size limitation.
More info- free unlimited ost to pst converter
Cigatisol
You can use one of the best Cigati OST File Recovery Tool to retrieves the data from the Corrupt OST files in just no time. It can allows the users of the OST file to scans offline storage table (.ost) file and previews or save emails from the OST file with great ease. The tool is highly compatible with all the versions of Windows 10 and its below version.
ruchika
1. Browse OST file ----------------> 2. Preview MAils Items----------------------------> 3. Export to PST File
Recovery of inaccessible or corrupted OST file and its mailbox data items isn't an easy task until you use DRS OST File Recovery Tool. The software has a capability to recover highly corrupted or inaccessible Exchange OST file along with its attachments. Using its different recovery modes, you can simply recover OST data from its several corruption state. It is equipped with highly secured and easy user interface. It supports all the MS Windows versions.
Since OST files are prone to corruption, it can be challenging to recover data from them once they have been damaged. Therefore, the SysInfo OST recovery software easily converts Exchange Outlook OST data to PST, MBOX, and other file formats while successfully fixing inaccessible or corrupt OST files. Using the OST file recovery software, you can save recovered OST files in various formats, including PST, EML, MSG, DBX, and MBOX. On the other hand, this software is simple and requires no special knowledge to operate. For a free performance assessment, you can use the Free OST Recovery Tool, which is compatible with all Windows versions.
You can follow some easy steps to fix Corrupt OST file . We can work on Outlook even while it is offline thanks to OST files. However, many Outlook users frequently experience OST File corruption. If the manual procedure is unsuccessful, the corrupt OST file can only be repaired via OST Recovery. In this post, we've covered every method that can be used to inspect and fix Corrupt OST files.
