OST to MBOX Converter
camilia
I am here with the best OST to MBOX converter software that will convert OST files to MBOX Thunderbird without any hassle. This software is built with an amazing technique to import Outlook OST to MBOX Thunderbird whether it is corrupt, damaged or inaccessible by the user. Support multiple saving options to save OST file into MBOX Thunderbird PST, Zimbra, Gmail, EML, EMLX, MSG, vCard, ICS, MBOX, and etc.
Show the preview of all OST to MBOX emails including these items:
Messages
Embedded Images
HTML Formatting
Header's Details
Contacts
Calendar
Tasks
Notes
Journal.
  • Message Filtering: This option allows you to export OST to MBOX items as per given date range.
  • Folder Selection: You can also select/ deselect OST to MBOX folders from the left pane of the software. This option helps you to export only required folder(s).
MOre Info- https://www.kdetools.com/ost/mbox/
If you are looking for a advanced solution to convert OST to MBOX then you can try this third party tool tool that is very easy to use and you can instantly recover your valuable data by using eSoftTools OST to PST Converter Software. This tool helps you to convert any huge size of Offline OST file into PST, Office 365, EML, MSG, ICS, EMLX, VCF, MBOX, vCard, vCal. The free demo pack will show you all the features and functionalities of the application with it's working process and allows you to save its selective 50 items any file format. It also works on all MS Outlook versions like 2007, 2010, 2013, 2016 and 2019.
Read more information:
OST to MBOX Converter to migrate the entire OST to MBOX format. It is a great solution for performing the OST to MBOX conversion without losing any data. The tool enables the user to extract entire data from offline folders to MBOX format in a few moments without any modification of data. The tool carefully exports emails, email properties, and attachments into thunderbird.
More info visit here: www.toolsbaer.com/ost-to-mbox-conversion/
