OST to PST Converter- Best alternative for SCANPST.exe
ralphmiller
If you are facing crashes or other problems in Outlook due to corrupt OST file and MS Office inbuilt utility Inbox Repair Tool (SCANPST.exe) fails to repair .ost file then using a third-party OST to PST Converter Tool is best option to repair and recover corrupt ost file. This software is capable to handle any major corruption issues in OST file. Using OST to PST Software you can easily repair corrupt OST file & recover mailboxes and convert to PST and other email and contact formats.
Key Features
  • Can convert OST file to PST, MBOX, MSG, EML, EMLX, vCard & vCal formats.
  • Recover every folder including Inbox, Outbox, Sent Items, Deleted Items, Drafts, Contacts, Calendar etc.
  • Maintains email properties to, cc, bcc, date-time, subject & attachments after conversion.
  • Easily handle major corruption issues with OST file.
  • No limit of OST file size with this tool.
  • Supports Outlook 2016, 2013, 2010 and more versions.
  • Ability to export mailboxes from OST file directly to Office 365 & Exchange Server.
  • View recovered OST file emails in this same tool.
Learn More & Download- Office Microsoft OST to PST Converter & Recovery Tool for Outlook.
Instantly convert OST files into outlook pst files with the help of DataVare OST to pst converter software. This software helps you to convert OST File and convert into PST file. In this software have a advance features. It's work very sharp and quickly. OST to PST converter Software gives you the opportunity to select emails from damaged OST files and Export them into four PST format.
Use vMail OST to PST Converter software now to convert your OST file into PST. The process of this software starts with a deep scanning of OST file and then Recover OST and export into several formats such as PST, EML, MSG, EMLX, vCard and MBOX.
Download Now - vMail OST to PST Converter 5.5
To gain a better result than your expectations download InQuit OST to PST Converter tool. Through the help of this application the user can convert single as well as multiple files along with emails, contacts, inbox, drafts, calendars, deleted-items, sent items, outbox, notes (to, cc, bcc, subject, date and time) into PST and another file formats like EML, EMLX, MBOX, HTML, MSG, vCal, vCard as per your need. Before the actual conversion, you can see the recovered mailbox and restore the data into new PST file. The PST files save anywhere in your system. It supports Office365 & Live Exchange Server.
Read More Info: InQuit OST to PST
Download ATS OST to PST Converter tool that is the great application for the conversion process. Using it you convert single as well as multiple files in a few minutes without consuming more time. It supports all the version of MS Outlook like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. During the conversion of OST to PST your data always the same as before. It has the preview facility that shows the recovered mailbox before the conversion. With the aid of this application, you extract your data into several interesting file formats such as PST, EML, EMLX, vCard, vCal, MSG, MBOX, and HTML.
Read More info: Best OST to PST Converter
Just download SysOZ OST to PST Converter software which has deeply analyze the OST file data and after scanning you can easily preview the recovered emails information without facing any problem. The Convert OST to PST Tool is simply export the folder items inbox, deleted items, journals, contacts, calendar, notes, task, draft and other many items etc.
Read more: OST to PST Converter
Here is highly Vartika Advance OST to PST Converter that convert unrestricted size OST file to PST Outlook. Using this software you can convert OST file elements to MBOX, EMLX, vCal, vCard, EML, MSG, HTML and PDF formats. It gives you advance technique to convert OST to PST as well as import OST to Office 365/Live Exchange Server.
Get Software-
If you want best alternative that effortlessly convert OST to PST, then go with PDS OST to PST Converter because this software maintains data integrity when convert OST to PST and additional formats: - EML, MSG, Office 365, PDF, MBOX and HTML. I specially suggest because this is self-tested program to restore OST file into PST file and get back all emails in readable mode. This utility has free demo facility which restores 20 emails per folder into all formats free of cost.
Read more- Free to Convert OST to PST by using OST to PST Converter
For the instant and safe recovery of the damaged OST file, download eSoftTools OST to PST converter tool. It is one of the best OST to PST converter software, this tool auto locates the location of the OST file to help the user to find the location of the OST file. To access the information this tool also converts the OST file into 6+ various formats like HTML, PST Outlook, CSV, EML, MSG, Office 365, MBOX and vCard, while converting the OST file this tool does not damage any of the existing files. A smart preview is shown to the user before converting the file successfully into other formats, a FREE DEMO version is also available of this tool on the official website.
1336
