There are three possible methods to convert OST to PST. I am describing each method elaborately with their steps of implementation.
1. Import Export Method
To follow this method, you have to perform the steps below -
● First, you need to sign in to the outlook using an Exchange account.
● Then click on File and choose Open & Export.
● Now choose the Import Export option.
● Here choose export to a file option and tap Next button.
● Now select Outlook Data File(.pst) and select Next.
● Here, you have to choose the folder that you want to export and then click on Next
● Now select your desired location for saving the new pst file.
● After you have chosen the location click on the Finish button.
2. Archive Method
To follow this method, you have to undergo with the below steps -
● At first, open your Outlook account.
● Next click on the File option.
● Now choose Archive from the list.
● Next, select the file you want to archive.
● Select destination for the new archive file.
● Finally click on the Finish button.
3. Drag and Drop Method
To follow this method, you have to execute the listed steps-
● First, open your Outlook account.
● Now here you have to create a new PST File.
● Next select and pull all the folders you want to see in the PST File.
● Finally, select the Done option.
With the above three techniques, the manual method to convert OST to PST free ends here. No doubt that these are the best free methods available to users for exporting OST to PST format. But manual methods also have certain limitations on their own, and the users should be informed about them. I am disclosing here some genuine difficulties associated with this approach.
Drawback of Manual Approach for Convert OST to PST
- It is not suitable for any beginner or non-technical user.
- This is a lengthy and time-consuming activity.
- The file size is limited in this process.
- Some items in the mailbox get restricted for conversion.
- It is a very complicated process.
- No guarantee of data safety or integrity.
- High chance of file loss or misplacement.
However, if you are now worried about what can be the best solution to convert OST to PST Online. Then don’t worry, I have a reliable solution that is even recommended by experts of the industry. It is a professional tool that does your work very efficiently without hampering your important files.
Professional Tool to convert OST to PST
The
DRS OST to PST Converter is a smart software that is designed to export your OST files into PST can not only transfer file into PST format rather it works for many other file formats like MBOX, PNG, PDF, EML, TXT, CSV, HTML, DOC, JSON, etc. Data security is highly maintained by the software at the time of converting files from OST to other file formats. Moreover, the tool is also functional in exporting OST Files to different email clients such as Gmail, Yahoo, iCloud, Office 365, Yandex Mail, HostGator Email etc. If you have a large quantity of OST files for exporting then also the software can easily convert them in a one shot. Any non-technical or beginner user can run this application and perform the export task successfully. The tool is power packed with some excellent features that makes it unique from other softwares that are available in the market.
Notable Features of The Convert OST to PST Tool
● This software is capable of removing duplicate files at the time of conversion process.
● The tool is commanded with advanced features to easily convert even the highly corrupted files.
● The software offers a preview option to users before going for final export of the file.
● The tool allows users to skip the attachment files at the time of conversion.
● This software provides a download report for future reference of the process.
● The software is fit to run in all Windows versions like Windows 10,8.1,8,7, Vista, etc. It is also capable of working in MS Outlook 2019,2016,2013,2010,2007,2003.
● The tool facilitates users with a free demo version.
