OST to PST Converter tool
camilia
Get the best and reliable solution OST to PST Converter tool for the flawless conversion process. It can export OST to PST format with all the attachments. This utility offers the users to export the file in the batch format at once. Through its tool you can easily message filters by date, size and etc. The Software gives extra key feature to split large PST files into small PST files (25GB).
Key-features-
• Batch Conversion Option.
• Messages filtering option.
• Repair & Recover lost data from corrupted OST file.
• Export OST files into Outlook PST Files with all attachments.
• Save Multiple file formats like PST, EML, Zimbra, Gmail, Office 365, Live Exchange Server, EMLX, MBOX, MSG, vCal, vCard, HTML, NSF, PDF, and etc. file types.
more info- convert OST to PST outlook
OST to PST Converter Tool is an effective utility that converts the entire OST mailbox into PST including emails, attachments, images, drafts, calendar, address book, journals, appointments, etc. it supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019. A free demo version is also available for this software, user can easily transfer few emails into all available formats. Contact our Live Chat support team for any queries. They are available 24*7.
For the conversion of Outlook OST to PST user can convert single as well as more than one OST file in a few minutes. Using it you can easily recover the data from damaged file and then migrate them into new Outlook PST fiel along with full data of the OST mailbox.
To use this application, you don’t need to install MS Outlook on the system. This tool allows the user to choose only those emails or things that are needed. The tool maintains the internal structure of the folders of OST files while converting them into PST format.
This tool import corrupt OST data into PST file and other formats such as PST, EML, vCard, MSG, MBOX, HTML, vCal, and EMLX with full ease. If you want to use other formats then you can store the data into cloud-based application Office365 & Live Exchange Server that is an additional feature of this tool. This tool support MS Window 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
