OST to PST Converter
For the conversion task, The ATS OST to PST Converter application is the best that has lots of advanced features that make your conversion reliable. Using it recover the entire data from damaged OST file and convert into PST and other file formats such as EML, EMLX, MSG, HTML, vCal, vCard, MBOX file formats in a safe manner. Through the help of this program, you can see the preview of recovered mailbox before finishing the conversion. It is very supportive and advanced technology that provides a 100% accurate result. It backing the version of MS Outlook such as 2019, 2016, 2013, 2010, 2007, 2003, 2002, 2000, 98, and 97.
The feature of ATS OST to PST Converter Software
  • Convert the overall data from OST file to Outlook PST file formats smoothly.
  • Extract emails, inbox, sent the item, draft, delete-items, attachment, calendar, and notes at a one time.
  • The size of the OST file does not matter for the conversion purpose.
  • Divide the large OST file into several small PST files as per your need.
  • Migrate encrypted and password protected file without any hassle.
  • Provide 24x7 technical support just for your help.
Read More details: OST to PST Converter Software
Now convert Outlook data files from OST to PST quickly with DataVare OST to PST Converter in a few steps. This OST converter tool can recover corrupt mailboxes data from OST files and convert to multiple formats like EML, MSG, MBOX, EMLX, vCard & vCal.
Steps to convert OST to PST file
  1. Open OST file in OST Converter software.
  2. Choose to save the file type as PST and the destination folder in the Convert option.
  3. Click on Convert Now to save all Outlook mailboxes data as a PST file.
Import exported PST file in Outlook application to access all your emails, contacts, calendar etc.
eSoftTools introduces the best and reliable OST to PST Converter tool to convert OST file into PST Outlook and other multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML. It converts OST file with including all folders like E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent items, Calendar, Tasks, Notes, Journal folders. You can easily check the format of conversion with the help of smart preview available before the conversion. It supports all file versions of MS Outlook such: 2000, 2003, 2007, 2010, 2013, 2016, 2019 and also it can easily convert OST file without the installation of MS Outlook. A FREE DEMO version is available to the entire users, up to 50 emails from each folder can easily be converted into all formats.
I would like to suggest you Ignissta OST to PST Converter which is best OST to PST converter software.
# No File size limitations, Convert unlimited OST to PST file
# Convert OST file with multiple file format like PST, Office 365, MBOX, EML, MSG
# Provide 100% safe and secure conversion results with 100% accuracy results
Download trail edition of OST Converter and convert 50 emails per folder https://www.ignissta.com/ost-to-pst-converter/
Easy and Simple Process 1. Browse and select ost file 2. Preview Mail Items 3. Export to PST file
You can save your damaged OST database to PST, Office 365 & Live Exchange Server with the help of OST to PST Converter application. The software is designed by using the best algorithm and the best technology. It will allow to export single as well as more than one OST file into PST and other useful formats like EML, MBOX, vCal, vCard, EMLX and MSG.
Free demo version software is also available.
Read more:
