OST to PST Converter
camilia
The OST to PST Converter tool is the perfect tool to convert multiple OST files to PST at once. The tool comes up with many features. It offers multiple file naming options. With this software, users can easily save the converted files to the required location. The software provides the complete preview of OST files before the conversion. The tool supports all the versions of Windows OS & MS Outlook. It application to export Emails, mails from multiple OST files to PST format including PST, Zimbra, Gmail, Office 365, Live Exchange Server, PDF, EMLX, MSG, MBOX, HTML, and etc.
• Download , install and run OST to PST Converter.
• Click on the "Open" button to load OST file.
• There are two options to browse OST file(s).
Add File: To select OST file one by one.
Add Folder: To select folder of OST files.
Message Filtering: This option allows you to export OST items as per given date range.
• Folder Selection: You can also select/ deselect OST folders from the left pane of the software. This option helps you to export only required folder(s).
More Info- https://www.kdetools.com/ost/
Advance eSoftTools OST to PST Converter Software gives heaps of highlights to battle OST file recovery and conversion issues and makes simpler to recover OST emails and convert OST to PST file without losing any single byte of data. This software has the ability to convert huge size OST file without any data loss. The converter has the amazing features to recover corrupted OST files along with it's mailbox attributes like emails, tasks, drafts, journals, calendars, and contacts. It migrates OST file to different file platforms like MBOX, OST to MSG, OST to EML, OST to ICS, OST to vCard, OST to CSV (Excel) and OST to Office 365.
The freeware download software likewise accessible for prompt download from eSoftTools Official Website here-
