OST to PST Converter
Your OST files is corrupted and you can’t run our OST file don’t worry you are capable to access our MS OST file.PDS OST to PST Converter is a very Successive Software which can easily convert your OST files to PST without any damaged Outlook OST files after conversion that your complete data change into new healthy readable PST file and give option to save it in multiple formats such as PST, EML, MBOX, HTML, PDF and Office 365 comfortably. The OST to PST converter facilitates its user has a complete, clear preview of all the converted email items. The software performs with all Outlook file versions as well as Windows versions.
Read more: Free to Convert OST to PST by using OST to PST Converter
With the aid of OST to PST Converter application user easily convert email, draft, task, attachment, notes, contact, inbox, sent item, delete item ( To, Cc, From, Date, Time, Subject, Object and Bcc) from OST file to Outlook PST. With the aid of this program, users not only recover the data but also convert them into newly created healthy PST file. The best thing about this software is it is easy to use for everyone. Therefore, non-technical and technical users can easily operate it.
Great features
• Export email, draft, task, attachment, notes, inbox and contact etc. Into PST and other file formats like EML, EMLX, MSG, HTML, vCal, vCard, MBOX.
• Before completing conversion task it displays the preview of recovered mailbox.
• Using this tool users easily export OST data into Outlook PST file format.
• It is compatible to work with all MS Outlook versions like 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
• It supports cloud-based application Office365 & Live Exchange Server.
• It gives 24x7 technical support.
To over the corruption situation of outlook OST file, there needs to repair outlook OST file. However, you may not find the best tool to repair and recover OST files. But there I would like to recommend the most demanded tools Vartika OST to PST Converter Software that works to repair corrupted, damaged offline OST file and recover the entire data of OST files. The software uses a self-explanatory interface that guide the users to successfully convert the entire offline OST Files to PST Files. Once done the converted PST files can be imported back to MS Exchange Server in a single step. OST to PST Software supports all MS Outlook versions included- (32 Bit & 64Bit) 2019, 2016 & below versions (32 and 64 Bit) versions. With this software, you can retain access to entire emails include notes, emails, contacts, attachments, and journals, etc. OST to PST Export Software lets you save the converted emails into different types of formats such as- PST, EML, MSG, HTML, EMLX, Office 365 account and Live Exchange Server, etc. Moreover, all users can easily get a preview of the mail items before getting an accurate conversion process. The software helps in also convert selective folders from OST files into any formats.
To get more info:Vartika OST to PST Converter - Convert OST file into PST
For quick and easy OST to pst conversion, you can use a third-party option like Softaken OST to PST Converter. This tool can convert OST file to PST, EML, MBOX, MSG formats & also capable to directly migrate Outlook messages and other data into mail servers like Office 365.
