OST to PST Converter
camilia
Here Is a swift & master third-party solution to make an direct conversion corrupt OST to Outlook PST through Outlook OST to PST Converter Software.
This is the good solution for converting emails, mails from corrupt OST to PST outlook format. Its utility to transfer entire OST file data into Outlook PST file and various file types such as – Zimbra, Gmail, PST, EMLX, NSF, HTML, MSG, vCard, MBOX, vCal, PDF, EML and etc. file types and with cloud applications such as Office365, Live Exchange Server.
• There are no size restrictions for OST to PST conversion.
• User can split PST file into smaller files.
• Batch Conversion option
• Users can save all OST files into a single file or Convert a single OST into a single PST file.
more info- Download OST Converter
I suggest this eSoftTools OST to PST Converter Software users can easily operate this software you can see the Software preview there are some easy steps to OST recovery and OST Conversion user can save 25 items per folder. Migrate OST to and many other file formats like PST, Yahoo, Zimbra, Gmail, HTML, EMLX, EML, MBOX, Office 365, and vCard. download the free demo of the software.
Get More Details-
Migrate OST files
If you want to migrate OST to PST then you can make use of OST to PST Converter Software because this is good product which allows you to convert outlook OST to PST with full attachments- Inbox, Outbox, Sent Items, Deleted Items, Draft, Tasks, Calendars, Notes, and Contacts in just few minutes. You can Split large File into mini Size Files according to your need without affecting any data from your OST Database.
Through this OST to PST program, you can be recovered OST File to Restore OST Data into different formats like- HTML, PST, MSG, vCard, vCal EMLX, and EML formats. The user-friendly interface of this tool such a great which makes your conversion safe and secure. It gives an accurate result and the user can select those files which they want to transfer from OST file to Outlook PST.
This application can be installed in every version of OS Windows like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). With the help of the best technology user can see their all the data before the actual conversion.
It has the great capacity which allows you to migrate password protected and encrypted file in a safe manner. If you want to see its immunity power so you can download the free demo version from our official site and convert 30 emails per folder free of cost but to convert all emails item you will be paying money.
Get the best software to convert OST files to PST format along with 15+ different file formats with the help of the one and only OST to PST converter tool. This software comes with a simple GUI and multiple user-oriented features. Download and try a free trial version of this OST to PST conversion tool with all the related features of the full version.
Visit at ; https://www.osttopstapp.com/
