ralphmiller
Errors have been detected in .ost file is a common problem in Microsoft Outlook. The cause behind this error is corruption in OST file. There are many manual methods to fix this error in OST file like repairing OST file using the SCANPST.exe tool in Outlook or deleting corrupted ost file and then creating a new OST file. But there are some limitations with all these methods. Using the Scanpst.exe tool you can't fix heavy corruption in .ost file and this tool also not supports large size of OST files. Recreating a new ost file may lead to loss of some offline saved data. So, the best solution to fix corrupt OST file error is to convert OST to PST file using vMail OST to PST Converter and then open converted PST file into MS Outlook. Converting OST file to PST format makes all mailboxes easily accessible in Microsoft Outlook from corrupt OST file. vMail OST to PST Converter is capable to handle any type of corrupt .ost file and there is no ost file size limitation while using this tool. There is also no risk of any data loss during OST to PST conversion with this tool.
Read More about methods to fix "Errors in OST file"- Fix Outlook Error “Errors have been detected in your .OST file”
Download OST to PST Converter- vMail OST to PST Converter 5.5
