other default settings
Hi,
my problem is, that i will use DBAN with other default settings. As default is set Verify=LAST and as Wipe-Method DOD-Fast.
I would like to change these settings. Is there a tutorial for changing and compiling the source files?
CU SL
perda04
run time options
Have a look at the file syslinux.cfg for the available options. You can change the value for "DEFAULT" to a different label if you want one of the ones already defined or you can change a section below.
Thx for your help - i changed the config and it works fine now :).
Great tool.
