Outlook Cached Contacts Recovery
alex786
Auto complete list or cached contact is the contact that Outlook them as a cache in NK2format. Whenever you type something in the ‘To’ field, a subsequent list will pop to auto-fill. That list is called an autocomplete list. Due to an Outlook error or some corruption, your NK2 file may get corrupted, and you could lose all autocomplete email addresses cache.
Do not worry! We have come up with a solution to recover corrupted NK2 files. Shoviv Outlook Cached Contacts Recovery tool is an excellent tool to recover contacts from the corrupted NK2 files, export them into PST file format.
And all this is done without the risk of losing data. Through this software, you can save all recovered contacts in single or in multiple PST files.
This tool allows adding multiple NK2 files without the restriction on their size. The functioning/working of the software is simple for technical as well as non-technical users. No matter which Windows operating system you are using, this tool supports it.
This Outlook Cached contacts recovery software comes with the free trial version and using it, the user can recover the first fifty items per folder from corrupted NK2 files.
Read More: www.shoviv.com/outlook-cached-contacts-recovery.html
To perform Outlook cached contacts recovery, there is a manual and expert method but the manual method is not safe as there are chances of data loss. And if users is from a non-technical background then you may face error while performing the process, To overcome these issue users must try an expert way that will securely recover the maximum possible data (cached contacts) from corrupt NK2 files. Suitable with Windows 10, 8, 7, Vista, 2003, XP and 2000. Offer a free demo version to perform NK2 File Recovery.
