carlielevins
eSoftTools NSF to PST Converter Software is an easy-to-use program that converts NSF files to PST format with all emails, contacts, notes, calendars, journals, and more. It allows you to convert Lotus Notes files to Outlook PST files in a fast and secure manner. Any size NSF file can be easily converted to PST format. During the conversion, the NSF folder hierarchy and email components such as attachments, hyperlinks, to, cc, bcc, from, date, time, and so on are completely protected. To export NSF emails to PST file format, you don't need any technical knowledge.
Get More Info:- NSF to ST Conversion
