The eSoftTools NSF to PST Converter Software that scans all the selected NSF files including emails, tasks, drafts, journals, calendars, and contacts. It allows you to export batch migration in go. The tool allows you to export NSF files in bulk and lotus notes versions 10, 9.0.1, 9.0 and below versions. It gives you option to date range filter through which you can search the specific folder of Lotus Notes NSF file. The software maintains the folder hierarchy and has user friendly interface. It is compatible with all MS Outlook editions upto 2016.
Get more info: NSF to PST Converter
