ethanbrowns
Use the best InQuit OST to PST Conversion tool that has the great and advanced features for the conversion purpose. Using it you can extract single as well as multiple OST files into PST file and another file format such as EML, MSG, vCard, vCal, EMLX, MBOX, and HTML. This application has a preview facility which allows you to see the recovered mailbox before finishing the conversion. It gives 24x7 technical help if you have any difficulty in the conversion. This application has the free demo version which allows you to convert 30 emails per folder free of cost. With the assistance of InQuit OST to PST Converter tool you can convert single as well as multiple file formats along with Emails, (to, cc, bcc, subject, date and time). Using it the user save their result into several file formats such as PST, EML, MSG, vCard, vCal, EMLX, MBOX, and HTML. It shows the preview of recovered mailbox before the conversion then transfer the data into PST file format in a couple of clicks. It supports OS window version like 95, NT, 98, ME, XP, Vista, 7, 8, 8.1 and 10 (32 bit & 64bit). Not only this you can also split thee PST files into smaller bits from 1GB to 5GB before the conversion with the help of this software.
