Trooper140
Re: Problem with Computer Shutting Down
Sent: Sun Jan 30, 2011 11:56 am
by DavidHB
Sorry to be a pain, but could you please repost this on the Support forum proper. The idea of an open forum is that knowledge is shared. I try to respond to forum posts reasonably quickly, but cannot make the same promise for PMs.
Quote Trooper140 Problem with Computer Shutting Down
Sent: Sat Jan 29, 2011 10:01 am
by Trooper140
DavidHB-
Thanks for all you posts concerning issues with us inexperienced computer users. Your posts and advice have helped me get Eraser re-installed after Vista crashed on me last year. However, in one of your post about year ago, in order for the error that I had to be fixed, you talked about changing a setting in Windows which may cause your computer to take an extremely long time to shut down. I changed that setting and my computer will not shut down unless I hold down the power button. I don't remember what setting it was or even how to get back to reset that setting? Can you help? I know this is kind of vague and it might be impossible to figure out, but I figured I'd ask. The only time I shut down is after software updates, so I am not sure its even vital that I get this fixed. The computer appears to work fine. Thanks again for your time.
-Erik
by DavidHB
by Trooper140
DavidHB-
-Erik
