problems in setting default file eraser method
Paolo Raimondi
Hello, I've just installed an tried tu run Eraser for the first time.
When I enter "settings" window and try to set "default file eraser method", if I try to select an option using the scrolling button on the right, no option appears in the window (the window only turns to blue colour) but the following warning: ! An invalid file erasure method was selected. What should I do? Thankyou
Paolo
Can you reinstall by choosing 'run as' administrator from explorer? I think you might have a permissions error.
