I’ve been having some serious problems running XP. Last night I ran the Eraser program to clean unused space on my C drive. I left it running overnight. This morning  AVG antivirus ran automatically. Immediately after I started getting an error for any program I tried to run or any file Itried to open; “sample text .* is not a valid win32 application”.
I get the same error when trying to run programs through the Start menu or through the Start>Run command, however, I am able to use Task Manager to run programs & opwn files.
Everything that normally launches when I stat up has also stopped launching. In addition, when I attempt to shut down or restart I get the error “You do not have permission to shut down or restart this computer”. So I have had to restart manually via the power button. Tried running an additional virus scan after updating AVG, as well as updating & running a-squared Deep Scan. Chkdsk with the /f switch didn’t help either.
I also just noticed that I can only type text in any text field for 3-5 seconds before having to click inside the field again as the cursor disappears.
Does anyone know what the problem is? Did I wipe out vital files with Eraser?
Please help!
Matt
Please help!
Matt
