Make utilization of the best application eSoftTools Lotus Notes to Outlook Converter Software on the off chance that you are intrigued to recover NSF information to PST file and convert NSF to PST document with messages and attachments. The tool provides you the feature to export desired NSF files and also you can search them through date range filter. The batch process can be performed conveniently and also maintain the folder hierarchy. It is secure for utilizing and their numerous highlights are accessible, you can pick any component of the software to import NSF to PST and it is compatible with each adaptation of MS Outlook like-2019, 2013, 2010, 2007, 2003.
Get more info: Convert Lotus Notes to Outlook
