PST to MBOX Converter
camilia
The PST to MBOX Converter to migrate PST to MBOX format with all emails Clients. It is a great solution for performing the PST to MBOX conversion without losing any data. The tool enables the user to convert PST folders to MBOX format in a few moments without any modification of data. This tool is the exports emails, email properties, and attachments into thunderbird. Its third-party tool will give you the genuine solution for importing the data from PST file format to MBOX format. The user can easily operate this application by its unique and simple user interface.
Updated Key-Features to Convert PST to MBOX ( Thunderbird ) format-
More info- PST to MBOX Converter Tool to Export & Convert Outlook to Thunderbird
You can easily export PST to MBOX then I would like to suggest a third-party application like PST to MBOX Converter. The software safely export PST to MBOX and multiple file formats such as MBOX and etc. The software also export PST emails to MBOX very easily. The software maintains folder structure and metadata of email during the conversion process. The software is compatible with all the latest and oldest versions of Windows such as Windows 10, 8, 7, 2000, XP, Vista and etc.
