camilia
PST to MBOX Converter that effortlessly convert all your PST to MBOX thunderbird in three easy steps. You can also save your PST to MBOX file format with the help of this tool. This Software Convert all PST file data items to MBOX file and also maintains emails properties- to, bcc, cc, time, subjects and from, contacts, calendars, task, notes, inbox items, outbox items and appointments.
Launch PST to MBOX Converter by KDETools.
go to File option.
select Open & Export option.
choose Import/Export as shown in the screenshot below.
To read OST files in Outlook,
one needs to convert OST files to PST format.
As it is not possible to import OST file directly to Outlook, we recommend you to try a third-party tool or the same.
More Info- Convert PST to MBOX
go to File option.
